Съкръщения в автомобилната индустрия
4WD – Four Wheel Drive
4WS – Four Wheel Steering
ABC – Active Body Control
ABS – Anti Blokier System
AC – Air Condition
ACC – Active Cruise Control aktivni
ADS – Adaptive Dämfung System
AGS – Adaptive Gearbox Shift
ALB – Anti Lock Braking
ASC – Automatic Stability Control
ASC+T – Automatic Stability and Traction Control
ASMS – Automatic Stability Management System
ASR – Anti Schlupf Regelung
ATM – Adaptive Transmission Management
AUC – Automatische Umluft Control
AWD – All Wheel Drive
BAS – Brake Assyst
BST – Battery Safety Terminal
CAN – Controller Area Network
CDI -… Diesel Injection (Mercedes-Benz)
CFI – Central Fuel Injection
CNG – Compressed Natural Gas
CVT – Continously Variable Transmission
DBC – Dynamic Brake Control
dCi – diesel Commonrail injection (Renault)
DDE – Digital Diesel Electronics
DISA – Differenzierte Sauganlage sistem
DOHC – Double Over Head Camshaft
DME – Digital Motor Electronics
DSA – Dynamic Stability Assistance
DSC – Dynamic Stability Control
DSTC – Dynamic Stability & Traction Control
dTi – dizel Turbo intercooler
DTI – Dizel Turbo Intercooler
EBD – Electronic Brakeforce Distribution
EBV – Elektronische Bremskraft Verteilung
ECU – Engine Control Unit
EDC – Electronic Damper Control
EDC – Electronic Diesel Control
EDS – Elektronische Differencialsperre
EFI – Electronic Fuel Injection
EG – European Gas
EGR – Exhaust Gas
EMC – ElectroMagnetic Compatibility
EPS – Electronic Power Steering
ESP – Electronic Stability Program
ETC – Electronic Traction Control
ETS – Electronic Tracion System
EV – Electric Vehicle
FDR – Fahr Dynamik Regelung
FFV – Flexible Fuel Vehicle
FIRE – Fully Integrated Robotized Engine
F.I.R.S.T. – Fully Integrated Road Safety Technology
FPS – Fire Protecting System
GDI – Gasoline Direct Injection (Mitsubishi)
GPS – Global Positioning System
HDC – Hill Descent Control
HDi – Diesel injection (Citroën, Peugeot)
HP – Horse Power
HPi -… … injection
i, I – Injection direkten vbrizg goriva
IC – Inflatable Curtain
ICIM – Individual Control Intake Mainfold
IMS – Instant Mobility System
IRD – Intermediate Reduction Drive
ISOFIX – International Standard Organization FIX
ITS – Inflatable Tubular Structure
JTD – uniJet Turbo Diesel turbo dize
KW – Kilowatt
MPI – Multi Point Injection
NGV – Natural Gas Vehicle vozilo na naravni plin
OBD – On Board Diagnostic
PDC – Park Distance Control
PES – Poli Elipsoid System
PPD – Passenger Presence Detection
PRS – Programmed Restraint System
SIPS – Side Impact Protection System
SDI – Standard Diesel Injection
SMH – Societe de Microelectronique et d’Horlogerie
SOHC – Single Over HeadCamshaft
SPI – Single Point Injection
SRS – Supplemental Restraint System
STC – Stability & Traction Control
TC – Traction Control
TCS – Traction Control System
TDI – Turbo Diesel
VANOS – Variable Nockenwelle Steuerung
VDC – Vehicle Dynamic Control
VIS – Variable Induction System
VTEC – Variable valve Timing and lift Electronic Control system
VVT – Variable Valve Timing – intelligent
WHIPS – WHiplash Protection System
WET W – Engineered Tread
